Showing G53 coordinates
- fernandosf
- Thank you received: 17
20 Aug 2021 18:39 #218261
by fernandosf
Showing G53 coordinates was created by fernandosf
Please,
How can I see G53 coords on DRO ?
Once I touch-off I cannot go back to visualize G53.
- aleksamc
- Thank you received: 67
20 Aug 2021 19:00 #218264
by aleksamc
Replied by aleksamc on topic Showing G53 coordinates
You can look in Tool > linuxcnc status
- fernandosf
20 Aug 2021 19:11 #218265
by fernandosf
Replied by fernandosf on topic Showing G53 coordinates
tool ?
Where in QTPlasmaC ?
- aleksamc
20 Aug 2021 20:01 #218269
by aleksamc
Sorry, I didn't saw that it's PlasmaC.
Look somwhere in menu for "linuxcnc status".
- fernandosf
20 Aug 2021 20:38 #218275
by fernandosf
There is no menu in QTPlasmaC
but thanks.
but thanks.
- aleksamc
20 Aug 2021 21:30 #218278
by aleksamc
You can go another road.
Type in mdi:
G53 G1 X500 Y500 Z 20 (coordinates could be what you wish).
Then when machine moved to that coordinates, make offset for each axis the same as coordinates.
In such way, you will return to machine coordinates
Type in mdi:
- phillc54
- Thank you received: 2100
21 Aug 2021 02:33 #218290
by phillc54
Replied by phillc54 on topic Showing G53 coordinates
If your have another work coordinate sytem that hasn't changed, say G55 you could switch to that with MDI which will show the same as the G53 coordinates then switch back to G54.
- fernandosf
21 Aug 2021 19:41 #218342
by fernandosf
- aleksamc
21 Aug 2021 20:46 #218348
by aleksamc
Yes, the reality is a lot of the opportunities...
- beefy
- Thank you received: 58
21 Aug 2021 23:55 - 22 Aug 2021 00:06 #218360
by beefy
Replied by beefy on topic Showing G53 coordinates
This brings up an interesting question (for me that is) related to the saving of work co-ordinates.
Let's say I put 3 smaller pieces of sheet on the table. I use the cross-hair camera to go to the lower left corner of each one, giving them G54, G55, and G56 work offsets.
I'm in the middle of cutting and bang, a power outage, a PC brain fart, or had to do an e-stop, etc.
Would Qtplasmc have saved all these offsets to disk at the time they were created, so that when I start up the table again, I can simply home the machine and pick up from where the cut stopped.
In my last two softwares there was a toggle button to switch between machine and work co-ordinates. At the very start I'd actually take a photo of the XY machine co-ordinates at the work zero position so I could jog back there after say an e-stop or Z limit trip, and subsequent re-home, and then zero the work offset.
There was also an offsets tab where I could view the active Gxx offsets, plus there was a "Save Offsets" button on this page.
Do we have any such facility in Qtplasmac or should I just use Phil's hack and write down of take a photo of each work offset zero position.
EDIT:
Just been to this page:
linuxcnc.org/docs/2.4/html/gcode_coordinates.html
And read the following:
The values for offsets are stored in the VAR file that is requested by the INI file during the startup of an EMC.
So it appears that during program start up, the stored offsets are read.
Is this the case with Qtplamac.
Keith
EDIT:
Keith
Last edit: 22 Aug 2021 00:06 by beefy. Reason: Extra info to add to post
Time to create page: 0.419 seconds
