How to change from Ohmic to float switch
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Aug 2021 09:48 #218877 by mariusl
Hi
I have a machine that is fitted with a float switch and an ohmic probe (proximity sensors). I need to remove the ohmic function and replace the probing with the float switch.
I looked at all the usual files but could not find a way to do that. I could not find where the ohmic probe debounce output is used for instance so I am a bit lost here.
Regards
Marius
www.bluearccnc.com
27 Aug 2021 09:50 #218878 by phillc54
Replied by phillc54 on topic How to change from Ohmic to float switch
If it is a PlasmaC config it will be in the connections.hal file.
  • mariusl
  • Platinum Member
  • Platinum Member
27 Aug 2021 10:01 #218881 by mariusl
Replied by mariusl on topic How to change from Ohmic to float switch
I am looking at a backup of the config files. This is what I see. Dont know if it is complete or correct
#***** debounce for the float, ohmic and breakaway switches *****
# the lower the delay here the better
# each 1 is a 0.001mm (0.00004") increase in probed height result
loadrt  debounce          cfg=3
setp    debounce.0.delay  5
addf    debounce.0        servo-thread
setp  hm2_7i76e.0.encoder.00.scale -1
setp  hm2_7i76e.0.encoder.00.filter 1
setp  hm2_7i76e.0.encoder.00.counter-mode 1
loadrt and2 count=1
addf and2.0 servo-thread
#***** arc voltage lowpass cutoff frequency *****
#***** change to the cutoff frequency you require *****
setp plasmac.lowpass-frequency 0
#***** the joint associated with the Z axis *****
net plasmac:axis-position joint.2.pos-fb => plasmac.axis-z-position
net plasmac:arc-voltage-in hm2_7i76e.0.encoder.00.velocity => plasmac.arc-voltage-in
net plasmac:arc-ok-in hm2_7i76e.0.7i76.0.0.input-06 => plasmac.arc-ok-in
net plasmac:float-switch hm2_7i76e.0.7i76.0.0.input-04-not => debounce.0.0.in
# net plasmac:breakaway hm2_7i76e.0.7i76.0.0.input-03-not => debounce.0.1.in
net plasmac:ohmic-probe hm2_7i76e.0.7i76.0.0.input-03-not  =>  and2.0.in0
#net plasmac:ohmic-probe hm2_7i76e.0.7i76.0.0.input-03-not =>
net plasmac:ohmic-probe_out  and2.0.out => debounce.0.2.in
net plasmac:ohmic-enable plasmac.ohmic-enable  => and2.0.in1
net plasmac:torch-on => hm2_7i76e.0.7i76.0.0.output-01
# a 1 here allows multiple tools to be used
# gcode M3 S1 needs to be changed to:
# M3 $0 S1 for the plasma torch
# M3 $1 S1 for the scribe
# M3 $2 S1 for spotting
setp plasmac.multi-tool 0
# net plasmac:scribe-arm plasmac.scribe-arm => ***YOUR_SCRIBE_ARMING_OUTPUT***
# net plasmac:scribe-on  plasmac.scribe-on  => ***YOUR_SCRIBE_ON_OUTPUT***
Regards
Marius
www.bluearccnc.com
27 Aug 2021 10:05 #218882 by phillc54
Yea, that is the one. According to that you have a float switch on input 4 and ohmic on input 3
  • mariusl
  • Platinum Member
  • Platinum Member
27 Aug 2021 10:11 #218884 by mariusl
That is correct. The ohmic is put through an AND gate to disable the probe during cutting.
As I understand the float switch will act as a safeguard for the ohmic probe as it is setup at the moment. So the question is how do I ignore the ohmic and only use the float for probing?
Regards
Marius
www.bluearccnc.com
27 Aug 2021 10:14 #218885 by phillc54
In the Run Tab uncheck Ohmic Probe Enable.
  • mariusl
  • Platinum Member
  • Platinum Member
27 Aug 2021 10:28 #218889 by mariusl
And then I have to calibrate the float travel again right?
Regards
Marius
www.bluearccnc.com
27 Aug 2021 10:29 #218891 by phillc54
Yes, if you haven't been using it then it is best to be safe.
08 Nov 2021 10:06 #225652 by RNJFAB
Replied by RNJFAB on topic How to change from Ohmic to float switch
or '#' out the ohmic line in the Hal file
Time to create page: 0.460 seconds
