Probe Test fails
- CFE
- Thank you received: 35
13 Sep 2021 06:01 #220398
by CFE
Probe Test fails was created by CFE
Hi all,
We have migrated our plasma cutter from V2.8 with PlasmaC to V2.9 with QtPlasmaC. The machine is moving and homing no worries, I have setup homing as per QtPlasmaC guide. But Probe test is not working, the torch keep moving even after activation of the float switch. Single cut is also not working, and I tried a circle with conversational, but when I run that the torch finds the material, but then it throws an error saying the float switch is activated, program paused. Any idea what's is going on ?
Cheers, Peter
Cheers, Peter
- phillc54
- Thank you received: 2100
13 Sep 2021 06:15 #220401
by phillc54
Replied by phillc54 on topic Probe Test fails
If probe test doesn't work then it is doubtful that any cutting would work correctly.
When you do a probe test does the float switch LED turn on when the material is sensed?
Was the migration done with the qtplasmac-plasmac2qt wizard?
Could you post the config backup from the backup button.
- CFE
13 Sep 2021 06:34 #220404
by CFE
Replied by CFE on topic Probe Test fails
Hi Phil,
I have attached the backup files from the machine.
Meanwhile I did find that in the hal file the line:
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
was previously at joint 2, I have changed as above. But probe test still not working.
It's probably something obvious but buggered if I know what it is. And I love your work, that QtPlasmaC looks fantatic !
- phillc54
13 Sep 2021 07:08 #220405
by phillc54
You have four joints, two for X, one for Y, and one for Z which is joint3, so it should be joint.3.pos-fb
Mode 0 means you are using the arc voltage for a soft arc ok but you also have a parport pin for arc ok, if that is correct then you should be using Mode 1
You have a parport pin for arc voltage but there is no encoder set, I can see that is caused by a mistake I made in StepConf when using multiple parallel ports. You could copy this section into your hal file as a temporary fix. I will post a fix for this later today or tomorrow morning.
Do you have combined limit and home switches or just home switches.
Can you describe how the float switch LED behaves when you do a probe test.
# ---ARC VOLTAGE ENCODER---
loadrt encoder num_chan=1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
setp encoder.0.counter-mode 1
setp encoder.0.position-scale 1
net plasmac:arc-voltage-raw encoder.0.phase-A
net plasmac:arc-voltage-in encoder.0.velocityDo you have combined limit and home switches or just home switches.
- phillc54
13 Sep 2021 07:39 #220406
by phillc54
I have pushed a fix for the encoder on parport #2
The following user(s) said Thank You: CFE
- CFE
13 Sep 2021 23:49 #220534
by CFE
Hi Phil,
Thank you, with your help we got the thing to run, everything seems to work now. Really appreciate your help and the work you put in !
Cheers, Peter
Cheers, Peter
- phillc54
14 Sep 2021 00:22 #220536
by phillc54
Great, glad you got it going.
- Jflesburg
- Thank you received: 7
13 Oct 2021 06:30 #223004
by Jflesburg
Replied by Jflesburg on topic Probe Test fails
What ended up fixing this? When I Probe Test, I get the same results. My axis continues traveling down even after the floating switch is activated, then raises back up when the probing times out, but with no errors reported.
- RNJFAB
- Thank you received: 59
07 Nov 2021 20:46 #225581
by RNJFAB
Replied by RNJFAB on topic Probe Test fails
Same.
When I check my float switch activates and registered in the Hal check, but the float switch led doesn’t light up.
- Online
- Thank you received: 7490
07 Nov 2021 20:51 #225582
Replied by tommylight on topic Probe Test fails
Did you add the input pin in hal ?
Time to create page: 0.435 seconds
