Moving a PlacmaC setup to QtplasmaC
- Clive S
- Thank you received: 486
30 Sep 2021 04:59 #221879
by Clive S
Moving a PlacmaC setup to QtplasmaC was created by Clive S
As the tittle. I need to move a PlacmaC setup to QtplasmaC I have MXlinux running with a setup using QTplasmaC (my own config)I have cloned the drive and want to use the cloned drive.
Can I just edit the hal and ini files from the PlasmaC config to the QT config.
- phillc54
- Thank you received: 2100
30 Sep 2021 05:02 #221880
by phillc54
Replied by phillc54 on topic Moving a PlacmaC setup to QtplasmaC
If you copy the machine config into the config directory then try to run linuxcnc with that config it "should" migrate it automatically if you agree at the prompt.
- Clive S
30 Sep 2021 05:16 #221882
by Clive S
Thanks Phill.
Can I do this on a PC that is not connected to the Mesa 7i96 ?
Replied by Clive S on topic Moving a PlacmaC setup to QtplasmaC
Thanks Phill.
- phillc54
30 Sep 2021 05:20 #221883
by phillc54
TBH I am not 100% sure but I think it will work as it should check for the update before it attempts to load the Mesa stuff.
It won't hurt to try seeing as you have a copy.
P.S. Gaby said hello.
