QTplasmac jog keyboard keys not working
- Clive S
- Thank you received: 486
03 Oct 2021 09:55 - 03 Oct 2021 09:59 #222110
by Clive S
QTplasmac jog keyboard keys not working was created by Clive S
On making a pncconf config using QTplasmac I have it working apart from the keyboard jog keys.
Where should I start looking for this ?
Edit: This was using MXmint 2.9
Last edit: 03 Oct 2021 09:59 by Clive S.
- snowgoer540
- Thank you received: 907
03 Oct 2021 10:03 #222111
by snowgoer540
Replied by snowgoer540 on topic QTplasmac jog keyboard keys not working
On the parameters tab (or settings tab depending on the screen resolution), ensure "KB Shortcuts" is checked (it is not by default).
- Clive S
03 Oct 2021 11:10 #222115
by Clive S
Replied by Clive S on topic QTplasmac jog keyboard keys not working
You are a star Snowy I new I had seen it some ware. ThanksOn the parameters tab (or settings tab depending on the screen resolution), ensure "KB Shortcuts" is checked (it is not by default).
- snowgoer540
03 Oct 2021 11:11 #222116
by snowgoer540
That one still bites me sometimes
- Clive S
03 Oct 2021 11:16 #222117
by Clive S
I don't think that was in earlier versions.
One more thing unrelated. Is it possible to bring the ssd to another PC without a mesa card to get it loaded
as you know it fails without the 7i96 connected.
I make several clones with Zonzilla it makes it very fast to setup another machine.
- snowgoer540
03 Oct 2021 12:20 #222122
by snowgoer540
I believe it's been there since the public inception, but it's a "set it and forget it" kind of setting, so it's easy to forget about (hence why it bites me sometimes as well
). It is recorded in the .pref file though, so if you had a new machine you could place it there manually and it should work from the get-go.
You could do the behind-the-scenes config stuff, but I reckon the 7i96 card needs to be present to load LinuxCNC / GUI.
- Clive S
03 Oct 2021 12:25 #222123
by Clive S
- Clive S
03 Oct 2021 16:39 #222145
by Clive S
What would be a nice text editor for MXlinux ?
Yes I agree
- Thank you received: 7505
03 Oct 2021 16:57 #222150
Replied by tommylight on topic QTplasmac jog keyboard keys not working
Geany.
Time to create page: 0.094 seconds
