Qtplasmac 1.0.98 error on shutdown python segmentation fault
24 Mar 2023 22:41 #267451 by edgemir
Hi, Today I'm installing debian bullseye and builded the packages from source, I removed all packages for espeak, but still appear the error on shutdown, after that I modified the audio_player.py but it didn't work...
there is another option?
Thanks for help.
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Mar 2023 05:26 #267458 by rodw
Debian bookworm is  a better option than Bullseye in my opinion. Follow my step by step guide, no need to complie source anymore and better, faster kernel...
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
The following user(s) said Thank You: edgemir
25 Mar 2023 15:47 #267500 by edgemir
Ok Rod, thank you.
26 Mar 2023 15:40 #267554 by edgemir
Hi Rod, yestrday I probeb the guide for Bookworm, but unfortunely the error is still appear on shutdown. The error still appears when closing the application, although the behavior is much better than the previous ones that I have tried, as you said. I know that there are no problems that affect the work of the CNC machine, but I don't feel comfortable seeing the error screen, thanks for your help.
  • rodw
  • Platinum Member
  • Platinum Member
26 Mar 2023 21:09 #267578 by rodw
The segmentaton fault was a QTVCP thing which I thought was resolved last time I looked.. I will check one of my bookworm installs with the qtplasmac sim.
Does it happen if you run a QTplasmac sim?
26 Mar 2023 21:51 #267581 by edgemir
yes, it happens with the sample configuration of QTplasmac and with a new configuration made with Stepconf, I have tried both ways.
27 Mar 2023 18:59 #267646 by snowgoer540
I do see that it's back, I have no idea what changed recently to bring it back.
At any rate, in the meantime (which this may not get resolved any time soon, if ever), it's benign, so just ignore it.
03 Apr 2023 15:49 #268199 by snowgoer540
I pushed a change that seems to fix this over here (and on Chris' machine as well).... but I've said that before :)
04 Apr 2023 13:33 #268279 by edgemir
The error don't appear anymore, thanks
Time to create page: 0.337 seconds
