Qtplasmac 1.0.98 error on shutdown python segmentation fault
3 years 7 months ago #267500 by edgemir
3 years 7 months ago #267554 by edgemir
Hi Rod, yestrday I probeb the guide for Bookworm, but unfortunely the error is still appear on shutdown. The error still appears when closing the application, although the behavior is much better than the previous ones that I have tried, as you said. I know that there are no problems that affect the work of the CNC machine, but I don't feel comfortable seeing the error screen, thanks for your help.
3 years 7 months ago #267578 by rodw
The segmentaton fault was a QTVCP thing which I thought was resolved last time I looked.. I will check one of my bookworm installs with the qtplasmac sim.
Does it happen if you run a QTplasmac sim?
3 years 7 months ago #267581 by edgemir
yes, it happens with the sample configuration of QTplasmac and with a new configuration made with Stepconf, I have tried both ways.
3 years 7 months ago #267646 by snowgoer540
I do see that it's back, I have no idea what changed recently to bring it back.
At any rate, in the meantime (which this may not get resolved any time soon, if ever), it's benign, so just ignore it.
The following user(s) said Thank You: edgemir
3 years 6 months ago #268199 by snowgoer540
I pushed a change that seems to fix this over here (and on Chris' machine as well).... but I've said that before :)
