Config for a XY PlasmaC Help
10 Oct 2021 16:58 #222800 by swepeter
Config for a XY PlasmaC Help was created by swepeter
Hey
Is it possible to configure the PlasmaC with no Z axis?
I only want X and Y like a laser engraver.
I am running a mesa 7i96 card.
My second problem is the "plasmac:torch-on".
I have connected a led on the out01 TB3 to simulate, but it never lights up.
This is my config now
How can I get around the net plasmac:float-switch?
#***** PLASMA CONNECTIONS *****
#net plasmac:arc-ok-in hm2_7i96.0.gpio.001.in => db_arc-ok.in
net plasmac:float-switch hm2_7i96.0.gpio.000.in => db_float.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => db_breakaway.in
# net plasmac:ohmic-probe {YOUR OHMIC PROBE PIN} => db_ohmic.in
# net plasmac:ohmic-enable plasmac.ohmic-enable  => {YOUR OHMIC ENABLE PIN}
net plasmac:torch-on => hm2_7i96.0.gpio.001.out
#net plasmac:move-up hm2_7i96.0.gpio.002.in => plasmac.move-up
#net plasmac:move-down hm2_7i96.0.gpio.000.in => plasmac.move-down
#***** MULTIPLE TOOL ENABLE *****
# set to 1 to enable a scribe or spotting
setp plasmac.multi-tool 0
#***** SCRIBE CONNECTIONS *****
# net plasmac:scribe-arm plasmac.scribe-arm => ***YOUR_SCRIBE_ARMING_OUTPUT***
# net plasmac:scribe-on  plasmac.scribe-on  => ***YOUR_SCRIBE_ON_OUTPUT***
# FAKE ARC-OK CONNECTION
net plasmac:torch-on => db_arc-ok.in
Thanks for the help
/Peter
10 Oct 2021 18:48 #222810 by phillc54
Replied by phillc54 on topic Config for a XY PlasmaC Help
I am not sure if it relies on having a Z axis, you could try it and if it fails just make up a simualated Z axis.
Did you have the torch Enabled?
11 Oct 2021 03:42 - 11 Oct 2021 03:44 #222826 by swepeter
Replied by swepeter on topic Config for a XY PlasmaC Help
Yes it was enabled. I have tried the test torch button also but no luck.
Regarding the Z axis. It is looking for the float and if I have it always pressed I get an error that it was already pressed before probing.
Last edit: 11 Oct 2021 03:44 by swepeter.
11 Oct 2021 03:49 #222828 by phillc54
Check what the plasmac.torch-on hal pin does when you try to fire the torch.
11 Oct 2021 03:57 #222829 by swepeter
If I press the button so the float switch light goes off the Halmeter for plasmac.torch-on becomes true.
But the led on the Mesa out 01 is still dark
11 Oct 2021 04:00 #222830 by phillc54
I have just noted that you are using a 7i96, the output pin would be hm2_7i96.0.ssr.00.out-01
11 Oct 2021 04:10 #222831 by swepeter
Thanks! that worked.
Now just to the problem of not having a z axis
11 Oct 2021 04:17 #222832 by phillc54
If you post a backup of your config made from the Backup button in the Config panel I could take a look tomorrow to see if I can sort something out for you.
11 Oct 2021 04:26 #222833 by swepeter
So sorry what config panel?
11 Oct 2021 04:28 #222834 by phillc54
Time to create page: 0.206 seconds
