Laser Button qtplasmac
  • paulsao
  • paulsao's Avatar Topic Author
  • Elite Member
  • Elite Member
19 Oct 2021 19:13 #223605 by paulsao
Laser Button qtplasmac was created by paulsao
I am trying to make a button for Laser, I did a migration from Plasmac to qtplasmac and in my. Hal exists the connection net plasmac: laser-on and my output pin but in the ini file I don't know what is the code to activate it since I tried with qtplasmac. laser_on and it doesn't work.
19 Oct 2021 19:22 #223606 by snowgoer540
Replied by snowgoer540 on topic Laser Button qtplasmac
You need to the qtplasmac.laser_on to an output on your Mesa card. Additionally to get the LASER button to show up, you need to specify an XY offset in the ini file. It would be:
LASER_TOUCHOFF = Xoffset Yoffset
Here’s the section in the manual for the rest of the explanation on how to set it up and use it.
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#qt_laser
The following user(s) said Thank You: paulsao
  • paulsao
  • Elite Member
  • Elite Member
20 Oct 2021 15:53 #223703 by paulsao
Replied by paulsao on topic Laser Button qtplasmac
Thanks, I was able to make it work, it could be given as a suggestion to add a function to the camera so that it can obtain the center of a circumference or a piece that has already been manufactured and wants to be modified.
