THC not working
- bevins
- Thank you received: 338
20 Oct 2021 21:45 - 20 Oct 2021 21:57 #223754
by bevins
THC not working was created by bevins
I am running the latest QTplasmac on a new build.
I am using thcad and that seems to be sampling ok cause I am getting good volatages.
The voltage is getting sampled I imagine when it gets arc ok active is coming on when it gets up to 99% of feedrate.
Then while cutting, the voltages are changing while cutting a 3" circle from conversational tab, up or down never comes on. The piece is propped up a bit so it is on a slight angle so it should be coming on. The voltages vary up to 10-15 volts.
I am pretty sure I am missing something in the config I guess or something I am not doing properly.
Can someone look at my config I posted to see if something is wrong?
/edit running 2.9 master with the latest QTPlasmac with ohmic probing. XYZ gantry working fine. Using thcad-10
Thanks,
Thanks,
Last edit: 20 Oct 2021 21:57 by bevins.
- phillc54
- Thank you received: 2100
20 Oct 2021 22:21 #223758
by phillc54
Replied by phillc54 on topic THC not working
There seems to be some discrepency between the velocity and acceleration settings.
You should set all the JOINT velocitys and accelerations to what you require then set the corresponding AXIS velocity and acceleration to double the JOINT values. Then TRAJ MAX_LINEAR_VELOCITY should be at least the same as the highest JOINT velocity, for QtPlasmac it could be √ jointXmax_vel² + jointYmax_vel²
- Thank you received: 4155
20 Oct 2021 22:25 #223760
Replied by rodw on topic THC not working
Just to check my understanding. This is when both the X & Y axes are both at max velocity so travel is at 45 degrees using pythagoras. Is that right?There seems to be some discrepency between the velocity and acceleration settings.
- phillc54
20 Oct 2021 22:26 #223762
by phillc54
Yep, that's it. I normally don't bother as on my little table it doesn't make for a lot of gain.
- bevins
20 Oct 2021 22:39 #223766
by bevins
Thanks,
Replied by bevins on topic THC not working
OK will try working on the config. I didn't think this mattered. I just threw up some numbers to get it working and moving. I think I understand the correlation though.There seems to be some discrepency between the velocity and acceleration settings.
Thanks,
- phillc54
20 Oct 2021 22:41 #223768
by phillc54
There is a good chance that the low setting in TRAJ didn't let it get up to enough speed to get THC to activate. There is a THC Active LED that shows when it is active.
- Thank you received: 7505
21 Oct 2021 05:03 #223802
Replied by tommylight on topic THC not working
As a general rule, circles are not good for testing THC, use squares.
Also smal circles in wizard are done at 60% feed rate so the velocity lock is active all the time disabling the THC.
And set the VAD to 65-70%, default is way to high.
Time to create page: 0.094 seconds
