Question about THC parameters
5 years 6 days ago #224316 by phillc54
For mode2 it is a percentage of Z maximimum velocity
For modes 0 and 1 it is mutliplied by the current height error, so the speed is determined by the PID-P value and the amount of height error.
The following user(s) said Thank You: shizyo
5 years 6 days ago - 5 years 6 days ago #224371 by shizyo
sorry for a few more questions, how do you calculate or find out the current height error? Is the speed (PID_P x the current height error) in mm/ imperial unit or something else?
Last edit: 5 years 6 days ago by shizyo. Reason: typo
5 years 6 days ago #224373 by phillc54
Theoretically it is not height but voltage. It is the difference between the arc voltage and the target voltage. The result is used as a height change in machine units per servo period.
5 years 6 days ago #224375 by shizyo
Thanks for the explanation but I still don't know what speed my THC will be if I use PID-D in mode 1. My Z axis's max velocity is 4500mm, my PID-D is 10, my target voltage is 69 volt(cutting 1.2 mm stainless steel) and the arc voltage is 73 volt. From these information, can I calculate my THC speed? From your explanation, I will have 40 (10 x (73v - 69v). Is this 40 the speed of my THC in mm?
5 years 6 days ago #224381 by phillc54
I didn't realise that you needed the exact velocity of your THC so I was only giving you a simplistic answer, it is more complex than that as it also takes into account the scaling and the resolution of the Z axis eoffset and it will change every one millisecond.
Why do you need to know the exact value?
5 years 6 days ago #224426 by rodw
Replied by rodw on topic Question about THC parameters
Your torch speed will be up to your maximum velocity. The whole intent of a PID is it is a self adjusting algorithm that converges on the set point. If you google it, there are plenty of explanations.
Time to create page: 0.312 seconds
