THC with a pc keyboard
  • wasausky
  • Topic Author
  • New Member
  • New Member
5 years 1 week ago #224297 by wasausky
THC with a pc keyboard was created by wasausky
Hi everyone. I am adapting plasmaC for oxyfuel.
We know that it has no height control parameters so the thc will be operated manually by the user.
Is there a way with the keyboard to activate the pins of raising and lowering that plasmaC has or do you have to do a routine in python similar to Test?
Thank you for your answers
5 years 1 week ago #224300 by phillc54
Replied by phillc54 on topic THC with a pc keyboard
A this stage there is not. It would be possible to run in mode 2 and use external buttons connected to the plasmac.move-up and plasmac.move down hal pins.
We could maybe add an oxyfuel setting in the ini file which could enable some features required for oxyfuel. I don't know much (anything image missing /media/kunena/emoticons/smile.png) about oxyfuel.
  • wasausky
  • Topic Author
  • New Member
  • New Member
5 years 1 week ago - 5 years 1 week ago #224305 by wasausky
Replied by wasausky on topic THC with a pc keyboard
making a python program like this:
from pynput import keyboard as kb
def pulsa(tecla):
  print('Se ha pulsado la tecla ' + str(tecla))
def suelta(tecla):
  print('Se ha soltado la tecla ' + str(tecla))
  if tecla == kb.KeyCode.from_char('q'):
    return False
escuchador = kb.Listener(pulsa, suelta)
escuchador.start()
while escuchador.is_alive():
  pass
and call file in hal with loadusr I get what I wanted, only to each routine per key I would add activate the input hal of raising or lowering the torch.
now my question is if this program would consume many resources of the pc waiting for an event since it is simple.
Last edit: 5 years 1 week ago by wasausky.
5 years 1 week ago #224315 by phillc54
I have not used the keyboard module so I am not sure of the resources usued, you may be able to check it using htop.
5 years 1 week ago #224362 by rodw
Replied by rodw on topic THC with a pc keyboard
You can get capacitive THC sensors for oxy that have a ring around the torch near the material.
If you had one of those, plasmac might be more viable. Maybe using another spindle...
But I know less than Phill (less than nothing)
Time to create page: 0.052 seconds
