Little typo in the docs - Pulse hal pin
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Nov 2021 08:37 #225210 by rodw
IN this section,
linuxcnc.org/docs/devel/html/plasma/qtpl...html#qt_button-pulse
it says
The delay is specified in seconds, if the delay is not specified then it will default to one second.
I found this confusing. I think it should say something like:
The pulse duration is specified in seconds, if the pulse duration is not specified then it will default to one second.
04 Nov 2021 23:01 #225295 by phillc54
Replied by phillc54 on topic Little typo in the docs - Pulse hal pin
Fixed. Thanks for the report.
The following user(s) said Thank You: rodw, snowgoer540
  • rodw
  • Platinum Member
  • Platinum Member
04 Nov 2021 23:55 #225305 by rodw
Replied by rodw on topic Little typo in the docs - Pulse hal pin
Thanks.
See. Some people actually reads the docs you and Greg have put so much effort into!
Its really getting to be a kickass system and well worth the effort of upgrading
The following user(s) said Thank You: phillc54, snowgoer540
Time to create page: 0.072 seconds
