Gcode for enabling disabling VAD
- bevins
- Thank you received: 338
12 Nov 2021 12:24 #226217
by bevins
Gcode for enabling disabling VAD was created by bevins
Is there a gcode for enabling and disabling Void Anti-Dive?
I can add it to ruleset in Sheetcam but I need to know if there is a gcode available?
- snowgoer540
- Thank you received: 907
12 Nov 2021 17:26 - 12 Nov 2021 17:28 #226235
by snowgoer540
There isn't a way to enable or disable Void A/Dive via G-Code, but you can disable the THC (which is what Void A/Dive does automagically). If you were doing sheetcam rules, you could just disable the THC in areas where you expect to have issue with void crossing, or slugs falling out.
Otherwise, an update to the code that handles void sensing is in the works, and should allow the user to just leave it enabled "in case of emergency" (some unforseen event where the torch would dive, like running off the end of the plate during a single cut to sever, etc).
Replied by snowgoer540 on topic Gcode for enabling disabling VAD
Last edit: 12 Nov 2021 17:28 by snowgoer540.
- bevins
12 Nov 2021 18:06 #226236
by bevins
Replied by bevins on topic Gcode for enabling disabling VAD
OK we were having issues with after a hole it would dive, that's why we wanted to disable it automagically within the rules of sheetcam. The pressing issue is why is it doing it after a small hole cut with a hole rule that drops the speed which should in turn disable thc.
- Thank you received: 7478
12 Nov 2021 18:25 #226237
Replied by tommylight on topic Gcode for enabling disabling VAD
Remove lead out's.
- snowgoer540
12 Nov 2021 18:27 - 12 Nov 2021 18:36 #226238
by snowgoer540
It’s hard to say without seeing the gcode, etc. honestly… which Mode do you use?
another thought is you could halscope the THC status, with the VAD status, and the Z offsets to see if the THC was really disabled while the Z offsets were changing.
I say that because the gui significantly lags what is actually happening in the lcnc code.
Last edit: 12 Nov 2021 18:36 by snowgoer540.
- bevins
12 Nov 2021 18:46 #226240
by bevins
That's what I suspect is happening but not sure. Will be going there tonight and will see.
Remove lead out's.
- bevins
12 Nov 2021 18:51 #226242
by bevins
In Sheetcam if you do an outside layer/offset and do leadins, when you go to do inside offset the leadins are left there and you have to manually remove them or else you will get them in your gcode. I think he didn't remove them when he did his inside operation.
He is in the process of doing 720 pieces on a job with 1300 pieces. He said he isn't changing anything until the 720 batch is done.
Will look at it after this. But he is manually disabling the VAD for the profiles for now.
- phillc54
- Thank you received: 2100
12 Nov 2021 22:14 #226249
by phillc54
Replied by phillc54 on topic Gcode for enabling disabling VAD
The current iteration of Void Anti Dive is pretty ordinary. We are currently testing a new version which looks promising and it should not be too far away.
Time to create page: 0.206 seconds
