ohmic sense issue
- paulsao
- Thank you received: 22
13 Nov 2021 00:35 - 13 Nov 2021 00:39 #226260
by paulsao
ohmic sense issue was created by paulsao
Greetings to all.
I am trying to install ohmic3.comp for the ohmic probe of my plasma machine, the steps that I have already done are the following:
1) Change the firmware with metaflash to enable the other encoder --- OK
2) Install the ohmic3.com component using the command sudo halcompile --install ohmic3.comp --ok
3) Copy the spaceship_ohmic.hal file to the configuration folder and load it from .ini using HALFILE = spaceship_ohmic.hal --- ok
4) I added in my custom.hal file: setp hm2_7i76e.0.encoder.01.scale -1 setp hm2_7i76e.0.encoder.01.counter-mode 1 ---- ok net ohmic-vel ohmicsense.velocity-in => hm2_7i76e.0.encoder.01.velocity
5) Check in hal show these variables and the encoder --- ok.
6) Connect the other THCAD-10 with its corresponding resistance to the other input of the 7i96 card.--ok
Just when I start QTplasmac Ohmic probe the z axis just has no movement it does nothing. Greetings to all.
Last edit: 13 Nov 2021 00:39 by paulsao.
- Thank you received: 4132
13 Nov 2021 03:09 #226270
Replied by rodw on topic ohmic sense issue
When I am at work I will try and remember to share the current code and hal config I am using.
The following user(s) said Thank You: paulsao
- paulsao
13 Nov 2021 11:58 #226313
by paulsao
Replied by paulsao on topic ohmic sense issue
Thanks Rod
- paulsao
18 Nov 2021 19:49 #226912
by paulsao
Hi Rod could you help me with the setup for using ohmic3 please. Thank you.When I am at work I will try and remember to share the current code and hal config I am using.
20 Nov 2021 07:22 #227054
This thread has the hal and component source.
forum.linuxcnc.org/38-general-linuxcnc-q...-05?start=270#211023
Time to create page: 0.076 seconds
