Qtplasmac ohmic test inssue
- paulsao
- Thank you received: 22
18 Nov 2021 22:24 #226928
by paulsao
Qtplasmac ohmic test inssue was created by paulsao
Well so far everything works fine and it is time to change to ohmic probing, the homic enable pin works when using the ohmic test button, but the z axis does not move, it worked fine in plasmac but now that I change to qtplasmac I have that problem could someone help me.
- bevins
- Thank you received: 338
18 Nov 2021 23:40 #226932
by bevins
Replied by bevins on topic Qtplasmac ohmic test inssue
Post your hal files.
The following user(s) said Thank You: paulsao
- paulsao
18 Nov 2021 23:55 #226935
by paulsao
Replied by paulsao on topic Qtplasmac ohmic test inssue
Thanks for you help.
- bevins
19 Nov 2021 00:16 #226937
by bevins
You trying to use ohmic pobing or hypersensing
Cause you got them both in there some of hypersense is commented, ohmic probe.is there, and I see no ohmicsense component.
I would go through pncconf again and get ohmic probing setup first. Get that working then read up on Rod's hy[persensing. Do you have a working xyz machine with axis?
- paulsao
19 Nov 2021 00:24 #226938
by paulsao
Comment on the hypersense thing because the z axis was not moving, so I tried only with an ohmic probe to start in an easier way. When I did the qtplasmac migration I got that, I don't have another xyz machine.
Time to create page: 0.251 seconds
