Single cut not working after latest update
06 Dec 2021 04:59 #228415 by CFE
Hi all,
I have just updated QtPlasmaC to the latest version (v1.220.139) and wanted to rip off a bit of material with a single cut, but I get this error : "allow gcode filter to check if m3 happens before movements" and the machine doesn't cut. I see in the update list something has been done around this, but this breaks the single cut feature. What to do ?
Cheers, Peter
06 Dec 2021 05:22 #228417 by CFE
My apologies, the "allow gcode filter to check if m3 happens before movements" doesn't break the single cut feature. Rather, a single cut program seems to generate a M2 (End Program) and thus it won't start. I can start the single cut from the second line and then it works, but that's a bit of a workaround. Why is there a M2 at the start ? And can that be removed ?
Cheers, Peter
06 Dec 2021 09:59 #228430 by snowgoer540
Replied by snowgoer540 on topic Single cut not working after latest update
Peter,
Thanks for the bug report, a fix is forthcoming.  In the meantime, your workaround should work nicely.  Just a bit less automated.
-Greg
06 Dec 2021 11:19 #228432 by rodw
This worked for me today on the latest build
08 Dec 2021 03:41 #228591 by phillc54
Replied by phillc54 on topic Single cut not working after latest update
A fix has been pushed for this.
12 Dec 2021 22:02 #228951 by CFE
Hi all,
Thanks to everybody who chipped in, single cuts works again nicely !
Cheers, Peter
Time to create page: 0.152 seconds
