upgrade to current dev release and error on shutdown
- robertspark
- Thank you received: 216
02 Jan 2022 11:15 #230538
by robertspark
upgrade to current dev release and error on shutdown was created by robertspark
any suggestions/home/rob/linuxcnc-dev/scripts/linuxcnc: line 930: 5067 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
- phillc54
- Thank you received: 2100
02 Jan 2022 11:24 #230539
by phillc54
Replied by phillc54 on topic upgrade to current dev release and error on shutdown
There is an issue with espeak, if you uninstall python3-espeak it will get rid of the segfault but you will get a warning on startup.
The following user(s) said Thank You: robertspark
- robertspark
02 Jan 2022 11:52 #230542
by robertspark
Replied by robertspark on topic upgrade to current dev release and error on shutdown
thanks very much
