QtplasmaC removing none from ini file
16 Jan 2022 19:43 #232053 by Clive S
QtplasmaC removing none from ini file was created by Clive S
I have seen a post somewhere re. QtplasmaC removing "none" from ini file b but can't find it by Phill
I know it is to do with a recent update.   I don't see it in the manual.
16 Jan 2022 19:55 #232055 by snowgoer540
Replied by snowgoer540 on topic QtplasmaC removing none from ini file
I think you may be referring to the change he made to remove a redundant parameter from the LASER and CAMERA offsets?  This was done in version 1.220.149.
Commit here:  github.com/LinuxCNC/linuxcnc/commit/bd22...135e3fc553d3d417b7f3
Otherwise if not, you might have to wait for Phill.  Why do you ask?
16 Jan 2022 20:07 #232056 by Clive S
Replied by Clive S on topic QtplasmaC removing none from ini file
Thanks Greg that was it I forgot where it was.  Should it be noted in the manual ?
I was instructing a friend to update from some time back and knew that it would throw a wobbler with the ini file and I said he would have to remove a word ie "none" from the ini file as a one off.
16 Jan 2022 20:08 #232059 by snowgoer540
think it should have done it for you/him.  But I'm not 100% sure on that.
