I have an external THC that have a setting called DELAY_ARC_OK
It's manual says: "This parameter adjusts the delay of output activation after arc is started so that it is possible to stabilize the arc tension at start"
I have made some tests and have reached the minimum value of 0.3 seconds (less than that and I start to get "arc lost" messages)
The problem is I depend on lead-ins to avoid burning surrounding material (thin, like 1mm) at start, as the torch keeps still for 0.3 secs before THC send ARC_OK to LinuxCNC.
I have seen in the manual that there is a Gcode command for that (ignore ok), but it would imply waiting for the next line to reactivate it.
Is there a way to ignore Arc Ok for just 0.5 secs and then let LinuxCNC read that signal again normally ?
My goal is not to have lead-ins on some works where I can save both inner and outer parts. Right now, I get divots if I skip lead-ins, because of the waiting for the external Arc Ok signal.
