User Interfaces
Plasmac
Hole cut and fusión 360
paulsao
Offline
Elite Member
Thank you received: 22
04 Mar 2022 04:12 #236310
by paulsao
Hello everyone, today I did some hole cutting, I am using Qtplasmac and Fusion 360 pp, it is set to slow down to 60% to cut holes, but when I cut I see that the z axis changes the coordinates, so that the thc is not being blocked and it remains active throughout the cut, also sometimes when finishing cutting a hole the float switch is activated. Why is thc not blocked if the shear rate is lower?
User Interfaces
Plasmac
Time to create page: 0.191 seconds
