ohm sensor failure
- chuben
24 Mar 2022 03:22 #238202
by chuben
ohm sensor failure was created by chuben
Hi, I need help. I'm working with Qtplasma and the ohm sensor doesn't always load when I start linuxCnc.
Sometimes it works fine but other times it doesn't and I have to work with a floating torch.
What could be happening to me?
- phillc54
- Thank you received: 2100
24 Mar 2022 03:28 #238203
by phillc54
Replied by phillc54 on topic ohm sensor failure
Is the surface of the material reasonably clean and is the material well grounded.
- Thank you received: 4155
24 Mar 2022 04:01 #238205
Replied by rodw on topic ohm sensor failure
Could be oxidisation of the relay contacts. Add a pull down resistor. I use a 100 R 10 W, HS10 resistor.
what plasma cutter? what card?
- chuben
24 Mar 2022 04:47 #238208
by chuben
Replied by chuben on topic ohm sensor failure
I am using a Thcad-5 as an ohm sensor.
The plasma is a Hypertherm powermax 85.
And the surface is clean.
When I do HALLSHOW the values seem correct.
- Thank you received: 7505
24 Mar 2022 06:30 #238214
Replied by tommylight on topic ohm sensor failure
User "marke" got banned again, kept inserting links everywhere, not just where it was appropriate.
pretty sure he uses another account here, but that one is posting links only on topics related to what they sell.
He was already banned and un-banned before this.
25 Mar 2022 02:42 #238310
ohmic.comp in the main distribution or ohmic3.comp from the forum here?
Are you using a relay on the mains power? If so bypass or remove it so it stays on all the time.
Do you see the voltage in halshow hitting around 22-24 volts when probing? Is it going higher than the thresholds you have set?
Is it a water table? they are more problematic.
Sorry my remark about oxidisation was way off topic and not relevant. What component are you using?I am using a Thcad-5 as an ohm sensor.
- chuben
25 Mar 2022 03:19 #238312
by chuben
-How can I see if I am working with ohmi.comp or ohmic3.comp?
-I am not using any relay, I have an isolated power supply.
-The voltage I see is about 19.5V.
-I have a water table but I have tried it with water and without water.
Thank you for your reply.
25 Mar 2022 04:27 #238315
Can you share your hal and ini files or upload a compressed backup of your config folder?
Your threshold may be too high
- chuben
25 Mar 2022 09:10 - 25 Mar 2022 09:20 #238339
by chuben
esta es mi configuración
Last edit: 25 Mar 2022 09:20 by chuben.
- chuben
25 Mar 2022 09:17 - 25 Mar 2022 09:20 #238341
by chuben
Time to create page: 0.457 seconds
