User Interfaces
Plasmac
ohm sensor failure
ohm sensor failure
Thank you received: 4155
25 Mar 2022 16:11 #238375
Looks pretty good. Its just the Ohmic threshold is set higher than your voltage being read so it will never trigger
In custom.hal
# --- Configure the ohmic component ---
setp ohmicsense.thcad-0-volt-freq 136500
setp ohmicsense.thcad-max-volt-freq 965900
setp ohmicsense.ohmic-threshold 22
First check the 0 volt and max-volt frequencies agree with the sticker on your THCAD card.
If you have a voltage adjustment on your power supply, see if you can adjust it to read exactly 24 volts with a multimeter (not a biggie)
Check the ohmic-volts in halshow again
Adjust ohmicsense.ohmic-threshold to be about 2 volts below it. eg. about 17.5 volts based on your readings.
It should work,
The following user(s) said Thank You: chuben
User Interfaces
Plasmac
ohm sensor failure
Time to create page: 1.004 seconds
