- Thank you received: 5
How to Modify Probe Test Routine
- Daddio
- Topic Author
4 years 7 months ago #239709
by Daddio
How to Modify Probe Test Routine was created by Daddio
Hello,
I recently added a Z switch to my plasma table so that I could properly home my Z axis. I set my home offset 1 inch from my home switch which is located at the top of travel for my torch. So when Z is homed, it is up and away before X and Y move to their axis home.
When I move my torch into position I now find myself using the Probe Test button to align the torch to my material. The torch now moves a good 12 inches down, touches the material, and then moves all the way back to home position up top. How can I make the torch move to 1 inch above the material after probing instead of it going back to its home position?
Thanks!
Thanks!
4 years 7 months ago #239720
Replied by tommylight on topic How to Modify Probe Test Routine
Moved to "PlasmaC" section.
What are you using, PlasmaC or QtPlasmaC?
- phillc54
- Thank you received: 1802
4 years 7 months ago #239721
by phillc54
Replied by phillc54 on topic How to Modify Probe Test Routine
Home offset is the home switch position, home is where it moves to after tripping the home switch.
linuxcnc.org/docs/devel/html/config/ini-homing.html
- Daddio
- Topic Author
4 years 7 months ago #239738
by Daddio
Replied by Daddio on topic How to Modify Probe Test Routine
I am using QTPlasmaC on 2.9.
I am trying to change the final location after a probe test. Instead of Z returning to its home position after probing, I'd like it to retract 1 inch above the material it just probed.
- phillc54
4 years 6 months ago #239793
by phillc54
Probe test returns to the Z position it was at when the probe test button was pressed.
- Daddio
- Topic Author
4 years 6 months ago #239978
by Daddio
This is where I've gotten:
I call a subroutine from a new button, rapid down to z-5.0, turn on M66 to read the input of my float head switch, start a while loop to slowly go to z-6.0, then check the float head switch again, once the while loop is false go to z-1.0. The problem is the G01 Z-6.0 F10 call inside the while loop needs to complete before it will check the float switch again. Any suggestions on how to slowly move the torch down and have the M66 return value #5399 actually interrupt the motion?
O<goDown>SUB
G00 G90 G53 Z-5.0
M66 P0 L0 Q1
O<goDown-while> WHILE [#5399 EQ 0]
G01 Z-6.0 F10
M66 P0 L0 Q1
O<goDown-while> ENDWHILE
G00 G90 G53 Z-1.0
O<goDown>ENDSUB
M2
O<goDown>SUB
G00 G90 G53 Z-5.0
M66 P0 L0 Q1
G01 Z-6.0 F10
M66 P0 L0 Q1
G00 G90 G53 Z-1.0
O<goDown>ENDSUB
M2
- phillc54
4 years 6 months ago #240094
by phillc54
You could possibly use the LinuxCNC motion.probe-input and utilise the standard gcode probing routines:
linuxcnc.org/docs/devel/html/gcode/g-code.html#gcode:g38
You would need to connect the existing probe via HAL to motion.probe-input at the start of this routine and make sure it was disconnected when this routine was completed.
Time to create page: 0.246 seconds
