THC that controls z axis externally
30 Apr 2022 11:49 #241722 by Traza42
THC that controls z axis externally was created by Traza42
I've got a plasma set up here that uses a THC controller from China, It has an INPUT of Arc Start, Up, Down, Auto. And an OUTPUT of Arc-ok, trying to use plasmac and its wanting to INPUT of Up, Down, Ark-ok. Am I missing something easy to change that out, the THC handles everything with voltage and moving the z axis using a dc motor and external interface.
  • Moderator
  • Moderator
30 Apr 2022 12:52 #241726 by tommylight
Replied by tommylight on topic THC that controls z axis externally
Pictures?
30 Apr 2022 13:02 #241727 by Traza42
Replied by Traza42 on topic THC that controls z axis externally
30 Apr 2022 19:08 #241748 by rodw
Replied by rodw on topic THC that controls z axis externally
Plasmac mode 2 is designed for THC's like that
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#qt_mode
30 Apr 2022 19:11 #241749 by Traza42
From what I can tell mode 2 only works with up and down being inputs, not outputs, am I mistaken?
30 Apr 2022 19:32 #241751 by rodw
I expect your connections on the THC are actually outputs and the translation has been lost a bit. EG. To be connected to INPUTS.
DO you have documentation? what does the supplier say?
30 Apr 2022 19:36 #241752 by Traza42
Here's the manual that came with it, I will say that when it's powered up I can contact the up and down pins with the ground pin and it will move up and down
This browser does not support PDFs. Please download the PDF to view it: Download PDF
30 Apr 2022 19:42 #241754 by rodw
I found the manual. This is designed to control a DC motor not a stepper motor.
Its not really suited for Linuxcnc which controls Z axis position precisely.
Assuming you have the complete chinese table, I would replace the Z axis motor and gear box with a nema 23 stepper motor. If you are really lucky mounting hole positions will have been spotted.
I would then throw out the controller and THC and use a THCAD and 7i92/7i76e and let Linuxcnc manage the whole process. You will get much better results..
  • Moderator
  • Moderator
30 Apr 2022 19:56 #241758 by tommylight
I have to agree with Rod, had my fair share of removing those damn things and throwing them.
Good business for me though! :)
30 Apr 2022 22:58 #241765 by Traza42
Hmmmm, you think theres anyway to run with what I have for the moment? trying to at get this running asap then can modify later
Time to create page: 0.224 seconds
