Scale axis
- Thank you received: 7505
10 May 2022 11:53 #242503
Replied by tommylight on topic Scale axis
It should not....when the axis is squared by moving the limit switches, does that calculated scale change or does it not affect that at all?
Pulleys slipping, something bent, crooked or out of alignment...And I also don't know why in one part of the table I have a different value of distance to another part of the table.
The following user(s) said Thank You: paulsao
- paulsao
- Thank you received: 22
10 May 2022 13:11 #242511
by paulsao
Replied by paulsao on topic Scale axis
Well, remove the squaring switch and the axis scale is now fine, I don't know why.
- paulsao
11 May 2022 09:59 #242647
by paulsao
Well, after spending the whole night without sleeping, it occurred to me to change sides to the toothed band, that is, the part that works the most, change direction and the problem was solved, now the rear part that occupies the least has that error, that is to say that the belt teeth are worn. Does anyone know why I have to lubricate the band? Or is it too tight it's a 15mm wide htd3.
Time to create page: 0.286 seconds
