valid arc lost final cut.
  • paulsao
  • paulsao's Avatar Topic Author
  • Elite Member
  • Elite Member
13 May 2022 13:23 #242873 by paulsao
valid arc lost final cut. was created by paulsao
Greetings. I am experiencing at the end of some cuts a message of "valid arc lost" it seems that it occurs because some pieces are in the middle of the waterbed supports and immediately fall, someone could give me a suggestion, if I give it some time the end cut can solve these problems?
13 May 2022 14:26 - 13 May 2022 14:27 #242881 by snowgoer540
Replied by snowgoer540 on topic valid arc lost final cut.
Good morning.
The Valid Arc Lost is in this case is caused because the material fell away, the arc flamed out, and as far as QtPlasmaC is concerned, it still had some (likely very small) distance remaining in the cut.
I think the easiest way to solve this is to add this line to your custom.hal file:
setp plasmac.arc-lost-delay 0.1
This will allow motion to continue for up to 100mS, or until the next M5 gcode is reached.  Whichever comes first.
That should do the trick.
Last edit: 13 May 2022 14:27 by snowgoer540.
The following user(s) said Thank You: paulsao
Time to create page: 0.078 seconds
