QtplasmaC- actualization error
10 Oct 2022 18:01 #253898 by edgemir
Replied by edgemir on topic QtplasmaC- actualization error
I have a configuration that worked correctly before (the last one where it works is 7460), but after an update it no longer works for me. To test I have used the sample configurations and they work well, but the problem is if I change the configuration mode to type 2, it sends me VCPWINDOW errors, I have tried creating a new configuration from STEPCONF and in the same way in mode 0 and 1 they work normally, but if I change it to mode 2, it marks the errors that I have made previously, I attach the error report files, greetings and thank you very much for your support...
10 Oct 2022 21:16 #253917 by snowgoer540
Replied by snowgoer540 on topic QtplasmaC- actualization error
Thank you for the report. I just pushed a fix, it should be good to go as soon as the buildbot is done doing its thing.
The following user(s) said Thank You: edgemir
Time to create page: 0.070 seconds
