WARNING FOR USERS THAT RUN BUSTER
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Jun 2022 06:40 - 04 Jun 2022 07:09 #244571 by phillc54
WARNING FOR USERS THAT RUN BUSTER was created by phillc54
If you use Buster or equivalent and have a Run In Place install then do not do any updates, the recent document changes have broken the building.
If you have a package build from the Buildbot then you won't be able to update because it has broken the Buildbot as well.
Last edit: 04 Jun 2022 07:09 by phillc54.
The following user(s) said Thank You: tommylight, robertspark
09 Jun 2022 19:24 #244839 by andypugh
Replied by andypugh on topic WARNING FOR USERS THAT RUN BUSTER
I think it is OK now. (just tested a build)
If you want the translated docs and/or to build .debs then install po4a v0.66, which is now available from the Linuxcnc repository (so should show up in Synaptic and Apt)
The following user(s) said Thank You: phillc54, snowgoer540
  • Moderator
  • Moderator
09 Jun 2022 19:59 #244840 by tommylight
Replied by tommylight on topic WARNING FOR USERS THAT RUN BUSTER
Buster is very rude, breaking buildings and stuff ... :)
Time to create page: 1.024 seconds
