Update qtplasmac to latest with system from buildbot
- bevins
- Thank you received: 338
13 Jun 2022 15:47 #245076
by bevins
Update qtplasmac to latest with system from buildbot was created by bevins
I have an older QTPlasmac system I need to get updated to the latest version.
Problem is it was built with buildbot. I am afraid now that it probably wont work if I try to upgrade linuxcnc with the troubles with the buiodbot right now.
What are my options?
It is running master 2.9.0-pre0.3879.g9a26e69fe
Linux Mint 19.3
python 3.6.9
python 2.7.17
Linux Mint 19.3
python 3.6.9
python 2.7.17
- phillc54
- Thank you received: 2100
14 Jun 2022 06:29 - 14 Jun 2022 23:42 #245101
by phillc54
Replied by phillc54 on topic Update qtplasmac to latest with system from buildbot
Buildbot packages require python 3.7
To use the Buildbot packages you would require a distro with python 3.7 - Buster or MX19 are two that are known to work.
If you want to stick with Mint you will need to build locally and have two options for that.
Build for Run In Place:
Build a local package and install it:
Currently the no-docs option in package builds seems to have issues so you will probaly need to build the docs as well.
Edit: the no-docs option has been fixed.
Last edit: 14 Jun 2022 23:42 by phillc54.
- CFE
- Thank you received: 35
28 Jun 2022 06:48 #246051
by CFE
Replied by CFE on topic Update qtplasmac to latest with system from buildbot
Well bugger,
I thought I update QtPlasmaC to the latest version but of course that broke the thing, now I see this thread. Wish this python 3 thingy was announced in the update list
Is it possible to install python 3 on buster ?
Cheers, Peter
Cheers, Peter
- CFE
28 Jun 2022 07:06 #246052
by CFE
I have tried rolling back to an earlier version, but that seems not to work this time due to this python 3.7 requirement for buildbot. Stuck with a dead machine now. How can I get this to work ?
Cheers, Peter
Cheers, Peter
- phillc54
28 Jun 2022 07:09 #246053
by phillc54
Buster should have python3.
What is the result of entering python3 at a command prompt?
- CFE
28 Jun 2022 07:16 #246054
by CFE
Hi Phil,
I just installed python-3.7.9, but QtPlasmaC still throws an error. If I type "python3.7 -V" in the terminal it shows Python 3.7.9
- phillc54
28 Jun 2022 07:21 #246055
by phillc54
python 3.7 should have been the default python3 in Buster, LinuxCNC has required that for several months now.
What error are you getting?
- CFE
28 Jun 2022 07:21 #246056
by CFE
I saw in the error report whether "python3-gst1.0" is installed and I have tried to install that, but it seems the system is unable to locate that package. I suppose that doesn't help
- CFE
28 Jun 2022 07:25 #246057
by CFE
Here is the error report
- phillc54
28 Jun 2022 07:25 #246058
by phillc54
The package name is python3-gst-1.0
buster:~ $ apt search python3-gst
Sorting... Done
Full Text Search... Done
python3-gst-1.0/oldstable 1.14.4-1+b1 amd64
GStreamer GObject Introspection overrides for Python (Python 3)Please Log in or Create an account to join the conversation.
Time to create page: 0.109 seconds
