Update qtplasmac to latest with system from buildbot
- CFE
- Thank you received: 35
28 Jun 2022 07:27 #246059
by CFE
Replied by CFE on topic Update qtplasmac to latest with system from buildbot
Thanks Phil, and how do I install that ? Not a Linux wizard myself
- phillc54
- Thank you received: 2100
28 Jun 2022 07:30 - 28 Jun 2022 08:02 #246060
by phillc54
Replied by phillc54 on topic Update qtplasmac to latest with system from buildbot
I didn't know that python3-gst was a requirement but it seems it was added to qtvcp several days ago... a year ago.
sudo apt install python3-gst-1.0
Last edit: 28 Jun 2022 08:02 by phillc54.
- CFE
28 Jun 2022 07:34 #246061
by CFE
I have installed all the above discussed, but to no avail. Still a dead machine. Now what to do ?
- phillc54
28 Jun 2022 07:37 #246062
by phillc54
Can you post the errors from trying to run LinuxCNC from a terminal.
- CFE
28 Jun 2022 22:11 #246114
by CFE
Hi Phil,
I am out of the workshop this morning, but will have a crack this afternoon. What is the command to start QtPlasmaC from the terminal ? (I have never started it from the terminal.)
Cheers,
Cheers,
- phillc54
28 Jun 2022 23:19 #246121
by phillc54
It should be along these lines.
linuxcnc ~/linuxcnc/configs/<machine_name>/<machine_name>.iniPlease Log in or Create an account to join the conversation.
- CFE
29 Jun 2022 03:41 #246126
by CFE
Hi Phil,
I have started linuxcnc from a terminal with "linuxcnc /home/plasma/linuxcnc/configs/Plasma/Plasma.ini" and have attached the error files. No idea what to do with this. I suspect it has something to do with python ?
Cheers, Peter
Cheers, Peter
- CFE
29 Jun 2022 03:46 #246127
by CFE
Further to the above, I see the following file "/usr/share/qtvcp/panels/loadusr/loadusr.ui" is not present on the computer, which doesn't help I suppose. What to do ?
Cheers, Peter
Cheers, Peter
- phillc54
29 Jun 2022 03:49 #246128
by phillc54
That is a some kind of user panel, I have no idea why it is trying to load that...
Can you post the .ini file and ALL the .hal files
- CFE
29 Jun 2022 03:52 #246129
by CFE
Hi Phil,
I have attached the requested files.
Cheers, Peter
Cheers, Peter
