Is it possible to disable ARC_OK and still have THC UP/DOWN working?
  • fernandosf
  • fernandosf's Avatar Topic Author
  • Senior Member
  • Senior Member
23 Jun 2022 08:36 - 23 Jun 2022 08:48 #245678 by fernandosf
Or any ideas how to disable ARC_OK only for the first second after cut started.
I don't want the torch to remain on the same spot (burning surrounding materials of a thin plate) at all, but I do want THC to do it's magic (thin plate warps like hell).
Mode 2 here - my external THC only sends arc_ok after 0.3 secs (lower than this, LinuxCNC emits arc lost error).
Edit>  Maybe, it would be possible to set external THC arc_ok_delay to zero and increase dbounce arc_ok to something like 50, not sure if it's a good idea.
Last edit: 23 Jun 2022 08:48 by fernandosf. Reason: dbounce option
  • Moderator
  • Moderator
23 Jun 2022 10:04 #245685 by tommylight
In the hal file, add:
setp plasmac.arcok-in-delay 1
Do check the pin name as i am on the phone so this is probably the wrong name.
  • Moderator
  • Moderator
23 Jun 2022 10:06 #245686 by tommylight
Wait, wrong, why would you use arc on delay, it should be set to 0 on both sides. On the external one also.
  • fernandosf
  • Senior Member
  • Senior Member
23 Jun 2022 10:08 - 23 Jun 2022 10:11 #245687 by fernandosf
Because of this
Edit> Actually, I should have said that I need to set 0.3s on my external THC, otherwise, LinuxCNC emits arc lost error.
Last edit: 23 Jun 2022 10:11 by fernandosf.
  • Moderator
  • Moderator
23 Jun 2022 10:23 #245690 by tommylight
Set the external thc to 0, that is not negotiable if you want to avoid big holes. Then add just a bit debounce to arcok in LinuxCNC, just so it can pass the signal cleanly.
Adding delay to arcok will make that hole only bigger.
  • fernandosf
  • Senior Member
  • Senior Member
23 Jun 2022 12:58 #245708 by fernandosf
Thank's TommyLight, I'll try that.
Time to create page: 0.156 seconds
