Convert from Mach 3 with OLD hardware?
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Jul 2022 10:21 #246854 by mariusl
Hi
I have been asked to convert two plasma machines that run on Mach3 to PlasmaC. There is no question about that but now I found that I cannot get 7i76E or THCAD10  cards from Mesa. The machines have a parallel port driven UP/DOWN THC controller. The cut level is set manually via a potentiometer.
The question is, is it worth the effort to convert to PlasmaC using this kind of hardware and if it is worth the effort what functionality will I loose?
Or does anyone know of an alternative to Mesa hardware?
Regards
Marius
www.bluearccnc.com
08 Jul 2022 15:50 #246875 by snowgoer540
Replied by snowgoer540 on topic Convert from Mach 3 with OLD hardware?
Unsure of your location and the exact number of I/Os, etc, but maybe you could use the THCAD2 and 7i96s?
Also, there are plenty of plasmac machines being run on parallel ports. Mode 2 also accommodates external THCs.
  • Moderator
  • Moderator
08 Jul 2022 16:04 #246879 by tommylight
Replied by tommylight on topic Convert from Mach 3 with OLD hardware?
Parallel ports are looking rather appealing lately, had to dust off some old PC's a few days back.
08 Jul 2022 23:29 - 08 Jul 2022 23:29 #246919 by PCW
Replied by PCW on topic Convert from Mach 3 with OLD hardware?
THCAD-10s and THCAD-5s, and THCAD2s are all available from Mesa.
Unless you need a lot of I/O, a 7I96S is better suited to plasma applications than a 7I76E.
(We will have some 7I76Es in a month or so but are still constrained by parts availability)
Last edit: 08 Jul 2022 23:29 by PCW. Reason: formatting
  • mariusl
  • Platinum Member
  • Platinum Member
10 Jul 2022 14:41 #247017 by mariusl
Replied by mariusl on topic Convert from Mach 3 with OLD hardware?
Hi Peter,
That is good news indeed. I will have a look at that combination as I don't have a lot of I/O. Everything is currently handled by two parallel ports. I will be in touch shortly.
Regards
Marius
www.bluearccnc.com
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
11 Jul 2022 02:06 #247048 by Todd Zuercher
Replied by Todd Zuercher on topic Convert from Mach 3 with OLD hardware?
Linuxcnc can run it just using parallel ports to. If you want to.
  • mariusl
  • Platinum Member
  • Platinum Member
11 Jul 2022 07:07 #247061 by mariusl
I know that very well. I was asking about PlasmaC functionality that I will forfeit if I use UP/DOWN THC on a parallel port.
Regards
Marius
www.bluearccnc.com
11 Jul 2022 07:35 #247062 by phillc54
Replied by phillc54 on topic Convert from Mach 3 with OLD hardware?
Mode 2 has the following inhibited:
GUI arc voltage display
Height override
Void anti dive
PID control of THC speed - it does have rudimentry speed control.
  • mariusl
  • Platinum Member
  • Platinum Member
11 Jul 2022 07:53 #247063 by mariusl
Most of those are important functions. I will propose that we use the Mesa hardware instead.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.162 seconds
