Setting
- chuben
18 Aug 2022 16:04 #250036
by chuben
Setting was created by chuben
Hello, I need help with the configuration of my Z axis. It gives me a maximum limit error and I don't know how to remove it. I am sending you the error it gives me and my configuration files to see if they can help me. Thank you
- phillc54
- Thank you received: 2100
19 Aug 2022 04:24 #250065
by phillc54
Replied by phillc54 on topic Setting
Your QtPlasmaC is a very old version, can you update to the latest version and see if that has any effect.
If you have a buildbot package then you will need to wait until this build has finished as there was an issue with the update code.
buildbot.linuxcnc.org/buildbot/builders/....checkin/builds/9082
Your config works fine on a sim here using the latest version.
- chuben
19 Aug 2022 06:17 #250070
by chuben
Replied by chuben on topic Setting
Sorry for the inconvenience but I'm new to linux and how do I know if I have a buildbot package. Thank you
- Thank you received: 7509
19 Aug 2022 10:45 #250078
Replied by tommylight on topic Setting
How did you install LinuxCNC ?
- chuben
22 Aug 2022 03:53 - 22 Aug 2022 05:37 #250190
by chuben
Hello, I have updated Qtplasmac and now I get an error. What can happen?
Last edit: 22 Aug 2022 05:37 by chuben.
- snowgoer540
- Thank you received: 907
22 Aug 2022 17:32 #250234
by snowgoer540
Replied by snowgoer540 on topic Setting
- phillc54
22 Aug 2022 19:45 #250236
by phillc54
I made a sim from your new config and it works fine.
I don't undestand why it is doing the o-word call o<metric_startup>, that call was removed some time ago and is not in your new config.
Can you try to search for the call using the following, it will take quite a while.
grep -nrs 'o<metric_startup>' /Please Log in or Create an account to join the conversation.
- chuben
23 Aug 2022 05:56 - 23 Aug 2022 05:57 #250250
by chuben
en_US.UTF-8
Last edit: 23 Aug 2022 05:57 by chuben.
- chuben
23 Aug 2022 06:00 #250251
by chuben
How do I do that?
In a terminal and putting "grep -nrs 'o<metric_startup>' /" ?
- phillc54
24 Aug 2022 00:52 #250302
by phillc54
Yes, sorry for late reply.How do I do that?
The following user(s) said Thank You: chuben
Time to create page: 0.116 seconds
