Setting
18 Aug 2022 16:04 #250036 by chuben
Setting was created by chuben
Hello, I need help with the configuration of my Z axis. It gives me a maximum limit error and I don't know how to remove it. I am sending you the error it gives me and my configuration files to see if they can help me. Thank you
File Name: my_LinuxCN...3.tar.gz
File Size:14 KB
File Name: machine_lo...2-43.txt
File Size:0 KB
File Size:14 KB
File Size:0 KB
19 Aug 2022 04:24 #250065 by phillc54
Replied by phillc54 on topic Setting
Your QtPlasmaC is a very old version, can you update to the latest version and see if that has any effect.
If you have a buildbot package then you will need to wait until this build has finished as there was an issue with the update code.
buildbot.linuxcnc.org/buildbot/builders/....checkin/builds/9082
Your config works fine on a sim here using the latest version.
19 Aug 2022 06:17 #250070 by chuben
Replied by chuben on topic Setting
Sorry for the inconvenience but I'm new to linux and how do I know if I have a buildbot package. Thank you
  • Moderator
  • Moderator
19 Aug 2022 10:45 #250078 by tommylight
Replied by tommylight on topic Setting
How did you install LinuxCNC ?
22 Aug 2022 03:53 - 22 Aug 2022 05:37 #250190 by chuben
Hello, I have updated Qtplasmac and now I get an error. What can happen?
File Name: my_LinuxCN...5.tar.gz
File Size:14 KB
File Name: machine_lo...4-55.txt
File Size:1 KB
File Name: Placasbabak.ngc
File Size:4 KB
File Name: Trolas.ngc
File Size:19 KB
File Size:14 KB
File Size:1 KB
File Size:4 KB
File Size:19 KB
Last edit: 22 Aug 2022 05:37 by chuben.
22 Aug 2022 17:32 #250234 by snowgoer540
Replied by snowgoer540 on topic Setting
I am not immediately sure, since these load here.
One thought: what locale do you use?
22 Aug 2022 19:45 #250236 by phillc54
I made a sim from your new config and it works fine.
I don't undestand why it is doing the o-word call o<metric_startup>, that call was removed some time ago and is not in your new config.
Can you try to search for the call using the following, it will take quite a while.
grep -nrs 'o<metric_startup>' /
23 Aug 2022 05:56 - 23 Aug 2022 05:57 #250250 by chuben
en_US.UTF-8
Last edit: 23 Aug 2022 05:57 by chuben.
23 Aug 2022 06:00 #250251 by chuben
How do I do that?
In a terminal and putting "grep -nrs 'o<metric_startup>' /" ?
24 Aug 2022 00:52 #250302 by phillc54
How do I do that?
Yes, sorry for late reply.
The following user(s) said Thank You: chuben
Time to create page: 0.375 seconds
