Floating switch problem with plasmac
- beauxnez
- Thank you received: 10
24 Sep 2022 19:27 - 25 Sep 2022 09:41 #252679
by beauxnez
Floating switch problem with plasmac was created by beauxnez
I have this bob
www.hitmint.com/products/1pc-5-axis-mach...troller?currency=EUR
the floating Switch flashes on plasmac, if I connect it to the gnd it remains fixed?
youtube.com/shorts/xU2DiQJsGU4?feature=share
Last edit: 25 Sep 2022 09:41 by beauxnez.
- Thank you received: 7449
27 Sep 2022 12:01 #252848
Replied by tommylight on topic Floating switch problem with plasmac
Grounding/shielding issue, use shielded cable, ground everything at a single point inside the electronics box.
Trying to use the plasma while not properly grounded/shielded usually ends up badly.
Open up the "show hal configuration" and watch othe input pins, most probably the rest of them will also flash.
There is a very nice PDF by Hypertherm about grounding practices on the net, so do a search for it.
- beauxnez
27 Sep 2022 18:39 #252878
by beauxnez
Replied by beauxnez on topic Floating switch problem with plasmac
thank you, I haven't connected the plasma yet, just the drivers and stepper motor
27 Sep 2022 19:31 #252887
First link is to the PDF the second to a video on the same subject by Hypertherm, those are just the ground rules that can not be skipped for plasma.
www.google.com/search?q=hypertherm+groun...wAEB&sclient=gws-wiz
- beauxnez
01 Oct 2022 07:20 #253150
by beauxnez
problem solved, I changed the card thank you
Time to create page: 0.185 seconds
