Probe Test strange behavior
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Oct 2022 09:48 #253944 by mariusl
Probe Test strange behavior was created by mariusl
Hi
I am running the latest ISO 2.8 release with 7i96 and THCAD. The system is setup for mode 1 and I have a float switch on the torch.
When I push Probe Test the Z axis does not move at all and the countdown begins right away.
Is there any special setup that I need to do to use the float switch as the probe?
Regards
Marius
www.bluearccnc.com
11 Oct 2022 09:56 #253946 by phillc54
Replied by phillc54 on topic Probe Test strange behavior
The float switch should always work for probing.
Could you post a backup of the config from the Backup button.
  • mariusl
  • Platinum Member
  • Platinum Member
11 Oct 2022 10:43 #253949 by mariusl
Replied by mariusl on topic Probe Test strange behavior
File attached Phil
Regards
Marius
www.bluearccnc.com
11 Oct 2022 11:04 #253951 by phillc54
These are just quick observations on my phone, I won't get a chance to have a thorough look until tomorrow.
The Axis max velocity and acceleration need to be double the values of the corresponding joints.
Safe height is zero, it should be usually higher than probe height, I am not sure if it could cause this issue though.
Setup speed is very low, depending on scaling it may be too slow for motion to begin.
  • mariusl
  • Platinum Member
  • Platinum Member
11 Oct 2022 11:24 #253954 by mariusl
When you say setup speed do you mean probe speed.
The Z axis is quick at the moment. I did fix the joint settings as suggested.
If you set the safe Z at 0 it will use the maximum height. I did also change that to a bit higher than the probe height.
I made the probe speed 900 units per minute and still no movement
Regards
Marius
www.bluearccnc.com
11 Oct 2022 11:27 #253955 by phillc54
Setup Speed is down the bottom, currently it is 30.
  • mariusl
  • Platinum Member
  • Platinum Member
12 Oct 2022 18:35 #254025 by mariusl
Yes that was the issue. I did not understand the significance of that setting and how it was applied.
It is working very well now thanks man.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.149 seconds
