Can you please release a version for cutting tubes?
- taocitc
21 Oct 2022 06:40 #254649
by taocitc
Can you please release a version for cutting tubes? was created by taocitc
It is hoped that on the current basis, a version that can cut pipes such as round pipes, square pipes, and elliptical pipes can be launched. Is there any development plan for this in the future?
- Thank you received: 7485
21 Oct 2022 08:40 #254655
Replied by tommylight on topic Can you please release a version for cutting tubes?
Round pipes are easy, eliptical can be managed quite ok, sqare ..... not easy.
For round ones i use a normal XYZ config where Y is usually the round one, make configs for every diameter separatelly, and use Inkscape for CAM.
It is a sheet curled to a round shape, after all.
Also easy for use.
Square would need some work for sure.
Also easy for use.
- Thank you received: 4149
21 Oct 2022 22:00 #254730
Replied by rodw on topic Can you please release a version for cutting tubes?
Square needs fast Z axis accelleration and leave the change in height to be managed by the THC. This implies there will be a maximum cut velocity that is constrained by Z accel and size of the square.
Tube does not need a THC because the height will not vary.
Time to create page: 0.083 seconds
