Upgrade to QTPlasmac from very old Plasmac version
- Dee436
- Thank you received: 13
28 Oct 2022 16:27 #255310
by Dee436
Replied by Dee436 on topic Upgrade to QTPlasmac from very old Plasmac version
Hi Phil
Thank you for the reply
On my working installation the command gives the following output;
Linux Plasma 4.9.0-9-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.168-1 (2019-04-12) x86-64 GNU/Linux
This installation hosts a working run in place
On my new installation the command gives the following output;
Linux Plasma 4.19.0-22-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.260-1 (2022-09-29) x86-64 GNU/Linux
This installation has a basic pncconf setup that I have been gradually editing.
My current thinking is that I would be better to get a working implementation on the new install, as it will likely be a bit cleaner and also does not risk breaking my running install.
I would like that to be run in place also.
I have been looking at the hal and ini files and they do look quite similar.
I am not sure if Its best to copy my working files to the new install and edit them as best I can, or use the data from the files to create a pncconf implementation, or is there a better way?
Darren
Darren
- phillc54
- Thank you received: 2100
28 Oct 2022 22:31 #255346
by phillc54
Replied by phillc54 on topic Upgrade to QTPlasmac from very old Plasmac version
In that case I would be tempted to build a new config from scratch with PnCconf. Don't forget to run set the environment with rip-environment before running PnCconf.My current thinking is that I would be better to get a working implementation on the new install, as it will likely be a bit cleaner and also does not risk breaking my running install.
Time to create page: 0.131 seconds
