THCAD-5 Reading negative Voltages
- Deveraux
- Thank you received: 8
10 Jan 2023 21:02 #261493
by Deveraux
THCAD-5 Reading negative Voltages was created by Deveraux
I wired up my THCAD-5 today 4.9Mohm on the negative Lead of the plasma rectifier output to the THC.
Im using a Cebora PlasmaProf 52. i wired up positive input of the THCAD-5 to the rectifier output of the plasma cutter which had continuity to the clamp on the table for (which supposedly is on the positive voltage of the plasma cutter ).
I am getting readings from the THC but it is negative voltage. While cutting the negative voltage -3000 or so drops to -2600. (jumper set to 1/32) so the THC works somewhat without adjusting the settings...
But why am i getting negative voltage ? Should i just switch the cables at the rectifier to get positive voltage ? or is there a Setting to invert the voltage somewhere.
Appreciate the help
Luc
Appreciate the help
Luc
- Thank you received: 5335
10 Jan 2023 23:56 #261511
Replied by PCW on topic THCAD-5 Reading negative Voltages
Sounds like a scaling/setup issue
The input polarity is correct
- Thank you received: 7496
11 Jan 2023 00:08 #261513
Replied by tommylight on topic THCAD-5 Reading negative Voltages
PlasmaC or QTPlasmaC?
- Thank you received: 4153
11 Jan 2023 01:23 #261521
Replied by rodw on topic THCAD-5 Reading negative Voltages
You need this in your hall file. Change your encoder.01 to suit the encoder you are using. Likely .00
# --- 7i76e ENCODER SETUP FOR TORCH VOLTAGE ---
setp hm2_7i76e.0.encoder.01.scale -1
setp hm2_7i76e.0.encoder.01.counter-mode 1Please Log in or Create an account to join the conversation.
- Deveraux
11 Jan 2023 09:21 #261546
by Deveraux
Replied by Deveraux on topic THCAD-5 Reading negative Voltages
Thanks for the quick response im using PlasmaC currently.
I set up my encoder as follows:
# THC-5 ENCODER SETUP
setp hm2_7i96s.00.encoder.00.scale 1
setp hm2_7i96s.00.encoder.00.filter 1
setp hm2_7i96s.00.encoder.00.counter-mode 1
Since all of you say its not a wiring issue i will see which options work in the hal file mabye i need to change the scale to -1 as rodw pointed out.
I will post once i get it to work
11 Jan 2023 13:42 #261561
Encoder scale must be -1
- Deveraux
17 Jan 2023 08:39 #262218
by Deveraux
Had to leave town for a few days for work so i could not work on my machine.
Setting the encoder scale to -1 worked, thanks a bunch
The following user(s) said Thank You: tommylight, snowgoer540
Time to create page: 0.151 seconds
