Enable Auto hole cutting
18 Jan 2023 23:52 #262373 by RobKin
Enable Auto hole cutting was created by RobKin
In the plasmac user guide it says how to enable auto hole cutting 7.17
So how do I implement this?  To add code to the G-code does it have to be added to the post processor?  Or is it added to one of the files in the preference files?  Or does this have to be manually added to every ngc file I make from sheetcam?
So I want to add this?  Is this correct? Where does it go tho?
#<holes> = 3
#<holes> = 4
#<oclength> = .1
18 Jan 2023 23:57 #262375 by phillc54
Replied by phillc54 on topic Enable Auto hole cutting
It needs to be in the gcode file so yes, it should be done by the postprocessor.
Time to create page: 0.097 seconds
