jogging disabled if float switch triggered
- Thank you received: 4153
19 Jan 2023 08:28 #262388
jogging disabled if float switch triggered was created by rodw
I have recently upgraded qtplasmac but I can't remember what the version number is that I carefully wrote down at work!
I also recently repaired my float switch which has been busted for a few years (ohmic sensing rocks!)
I noticed that if jogging the z axis and you trigger the float switch, jogging is immediately disabled and the only way I could recover was to rehome the Z axis. Is there another method?
There are lots of good reasons you may wish to jog down to trigger the float switch for testing etc (which I was doing). I don't understand why everything is disabled in all directions. If jogging is happening, it implies a human is in full control and the torch is off so I don't understand why the machine overides a human operator!
Is there a way that the Z axis up jogging was permitted to recover from this fault? Its very time consuming to wait for homing.
- phillc54
- Thank you received: 2100
19 Jan 2023 08:34 #262389
by phillc54
Replied by phillc54 on topic jogging disabled if float switch triggered
19 Jan 2023 08:43 #262392
Replied by rodw on topic jogging disabled if float switch triggered
Thanks, I figured you had a setting somewhere.
I still don't understand why jogging is disabled in the first place. If you are jogging the Z you are watching the torch tip anyway.
- phillc54
19 Jan 2023 09:04 #262397
by phillc54
Because if we didn't have that feature and you broke your torch while jogging then you would complain about that.I still don't understand why jogging is disabled in the first place.
19 Jan 2023 09:05 #262398
Probably
- snowgoer540
- Thank you received: 907
19 Jan 2023 09:10 #262399
by snowgoer540
Replied by snowgoer540 on topic jogging disabled if float switch triggered
This is also an option:
linuxcnc.org/docs/devel/html/plasma/qtpl...og_inhibit_via_z_jog
I can’t recall because it’s intuitive at this point but you may have to press z+ twice (gui or keyboard). Once to turn off the inhibit and once to move the z axis up.
