Is there a way to disable THC locking?
- Sushi
21 Feb 2023 22:59 #264989
by Sushi
Is there a way to disable THC locking? was created by Sushi
Hi Everyone, I was wondering if it's possible to prevent the THC (THCAD-05/Mesa 7i96S) from locking the THC position? I want to be able to cut corrugated material, the wavy stuff.
Thank you,
Thank you,
- Thank you received: 7496
21 Feb 2023 23:23 #264991
Replied by tommylight on topic Is there a way to disable THC locking?
What are you using, PlasmaC or QtPlasmaC?
You would need a very fast Z axis to do that, and plenty of tuning, so might be a good idea to make a new config just for that as it does require changing several values.
- Thank you received: 4153
21 Feb 2023 23:52 #264992
Replied by rodw on topic Is there a way to disable THC locking?
You should be able to just disable velocity antidive or set a really low threshold/
The maximum possible cut speed is determined by the Z axis velocity. It is possible to calulate this using some formulas Dewey Garrett came up with.
I put them in a spreadsheet here (view only)
docs.google.com/spreadsheets/d/1kCE-M-3O...lr4/edit?usp=sharing
Set your pierce delay to zero and a short THC delay (0.01 sec or so- needs experimenting) Watch in halscope to determine what you can get away with.
I don't think there is any other settings required if you respect the Z axis velocity constraint.
- Sushi
22 Feb 2023 16:36 #265037
by Sushi
Replied by Sushi on topic Is there a way to disable THC locking?
I'm running QTPlasmaC. I'll definitely make a new config just in case, good advice.
22 Feb 2023 16:47 #265039
Moved to "PlasmaC" section.
- Clive S
- Thank you received: 486
22 Feb 2023 18:16 #265049
by Clive S
Replied by Clive S on topic Is there a way to disable THC locking?
Why ?
22 Feb 2023 18:57 #265055
There is no "QtPalsmaC" section.
And subject is QtPlasmaC that is a separate project based on LinuxCNC.
Time to create page: 0.098 seconds
