Invalid characters error when trying to use "IF" statement in GCode
05 Mar 2023 00:36 #265879 by xph1l
My very first post on this forum. Also pretty much my first CNC build - wasn't easy to set everything up in LinuxCNC but I just LOVE it.
I'm using LinuxCNC v2.9.0-pre0 with QtPlasmaC v1.233.249.
The issue I'm having is that when trying to use "if/else/endif" or "while/endwhile" statements in GCode, the QtPlasmaC throws an error "Invalid characters, line has been commented out".
Quick look into the source (main branch) and I found that it is triggered in src/emc/usr_intf/qtplasmac/qtplasmac_gcode.py, in illegal_character() function.
The code that triggered this is:
    elif line[0].isalpha():
        # line starts with two alpha characters (this could be refined)
        if line[1].isalpha(): return 1
This check was committed by:
commit 07f8e0af364e7c9594084e2c2b629f3bc45288bf
Author: Phillip Carter <phillcarter54@gmail.com>
Date:   Wed Dec 8 14:22:01 2021 +1100
    qtplasmac: gcode filter
    fix cut recovery bug
    add more illegal character checks
My question is: was this behavior intentional, or was it an error? If intentional, then why?
05 Mar 2023 00:38 #265880 by phillc54
Can you post the gcode.
05 Mar 2023 00:46 #265881 by xph1l
Sure thing. The "if" statement at the end of pre-amble is the culprit.
;     file name: mill_hook_small.tap
; date and time: Sat Mar 04 2023    09:09:11 PM
; postprocessor: LinuxCNC_PlasmaC_Mod_v1.scpost rev: 0.2
;begin pre-amble
 G21 (units: metric)
 G40 (cutter compensation: off)
 G90 (distance mode: absolute)
 M52 P1 (adaptive feed: on)
 M65 P2 (enable THC)
 M65 P3 (enable torch)
 M68 E3 Q0 (velocity 100%)
 G64 P0.254 Q0.025 (tracking tolerances: 0.254mm)
 if [#5400 eq 0]
  M30
 endif
;end pre-amble
;begin material setup
 T0 M6 (select plasma tool)
 G43 H0 (apply tool offsets)
 F#<_hal[plasmac.cut-feed-rate]>
 #<holes> = 2 (over-cut for small holes)
 #<oclength> = 3.5 (over-cut length)
;end material setup
 G0 X12.8 Y16.488
 M3 $0 S1 (plasma start)
 M67 E3 Q100
 G1 X9.901 Y19.387
 M67 E3 Q60
 G3 X9.901 Y19.387 I2.899 J-2.899
 M67 E3 Q100
 M5 $0 (plasma end)
05 Mar 2023 00:51 #265882 by phillc54
You need to use o codes in that case.
linuxcnc.org/docs/html/gcode/o-code.html
e.g.
 o100 if [#5400 eq 0]
  M30
 0100 endif
You can use names instead of numbers:
o<check_m30>  instead of  o100
05 Mar 2023 01:07 #265884 by xph1l
Awesome, it works! Thanks!
Sorry for bothering, but I've brushed over the o-codes page and haven't found the reason for having all conditionals under o-codes and not allowing to use IF as-is.
Maybe you know the reason on top of your head?
05 Mar 2023 01:10 #265885 by phillc54
Personally I don't know. LinuxCNC follows the RS-274 gcode standards so it is probably part of that standard.
05 Mar 2023 01:13 #265886 by xph1l
Got it. Will read up on that. Thanks for the help!
06 Mar 2023 23:53 #265992 by andypugh
It's partly because of the way G-code consists of single-character commands. The I of "If" is only valid after certain G-codes, but the "F" could be a feed rate command.
It's also partly because the parser doesn't have a loop / conditional stack to keep track of which IF belongs to which ENDIF. So the numbered O-words mean that if the condition fails the parser just needs to scan through the G-code waiting for the matching O else or O endif.
07 Mar 2023 22:43 #266081 by xph1l
Oh, it makes sense that O-words make parser less complicated. Thanks for the explanation!
Time to create page: 0.546 seconds
