Using M65 and M64 in pause mode
- DmitryKV
22 Mar 2023 09:10 #267283
by DmitryKV
Using M65 and M64 in pause mode was created by DmitryKV
Hello.
I have a task that I can't complete. The point is the following. I added a couple of buttons to the user interface, by pressing which commands from the handler are executed: ACTION.CALL_MDI('M65 P9') and ACTION.CALL_MDI('M64 P9'). Everything works fine until no G-code is executed. How can I control a digital port while paused or in motion while executing G-code? And in a pause you need more than in motion. Is it possible?
Regards, Dmitry
Regards, Dmitry
- Thank you received: 2181
24 Mar 2023 02:27 #267394
Replied by cmorley on topic Using M65 and M64 in pause mode
Not sure it helps but you can set digital output with the python module.
linuxcnc.org/docs/2.9/html/config/python...inuxcnc_command_code
set_digital_output(int, int)
set digital output pin to value
- DmitryKV
24 Mar 2023 08:45 #267400
by DmitryKV
Replied by DmitryKV on topic Using M65 and M64 in pause mode
Hello.
Thanks for the answer. I already tried this way. Does not help. Gives this message:
can't do it (EMC_MOTION_SET_DOUT) in automatic mode with read interpreter. According to the message, this is not possible.
In principle, I can implement the functions I need a little differently. But I can not find in the documentation whether what I want is possible. Maybe someone will tell?
In G code, I can read the state of the pins with: for example - P#<_hal[motion.analog-in-05]>. Is there a similar way to also set pins to a state? If there is, then I will create my own pins and will not use the digital pins of the motion module. I don't need to do this in real time.
Regards, Dmitry.
Regards, Dmitry.
- snowgoer540
- Thank you received: 907
27 Mar 2023 23:56 #267645
by snowgoer540
Replied by snowgoer540 on topic Using M65 and M64 in pause mode
what exactly are you trying to do? What are you controlling?
- DmitryKV
29 Mar 2023 09:57 #267786
by DmitryKV
Hello.
I have several auxiliary devices on the machine that need to be powered at certain times. I additionally insert control functions into the G code. I also need to be able to control them manually during the cutting process.
Additional devices are ventilation valves, damper electromagnets, in general, this applies to the cutting table. It can also be, for example, additional gases for a fixed methane torch.
Regards, Dmitry.
Regards, Dmitry.
Time to create page: 0.103 seconds
