Toolpath problem?
14 Apr 2023 16:12 #269007 by Tady
Replied by Tady on topic Toolpath problem?
Tested on 3 different machines and VM with MX Linux... It works on all of them. What could be the difference between these distros...
14 Apr 2023 16:19 #269008 by snowgoer540
Replied by snowgoer540 on topic Toolpath problem?
Literally anything/everything.
Like I said I didn’t have much luck with Mint. I found it slow and cumbersome and I can’t understand why people like it so much.
But to each their own.
Tommy has a mint installation tutorial around here if you’re still playing and want to give it a go.
14 Apr 2023 16:20 #269009 by snowgoer540
  • Moderator
  • Moderator
14 Apr 2023 17:56 #269015 by tommylight
Replied by tommylight on topic Toolpath problem?
That does not work anymore, Debian build of LinuxCNC requires Python 3.11, while Mint comes with 3.10.
But, if anyone has an earlier build, that works.
Did not bother upgrading Python, last time i tried that ended with 6 versions of it, and still it did not work. To many symlinks to chase.
The following user(s) said Thank You: Tady, snowgoer540
12 Oct 2023 12:01 #282811 by Franklin
Replied by Franklin on topic Toolpath problem?
hi, I have the same problem, the toolpath does not displayed.
This problem is not only on Mint, but also in Debian 12.
Everything works fine on other PCs. How can I solve this?
  • Moderator
  • Moderator
12 Oct 2023 12:28 #282812 by tommylight
In the prefferences page ( or settings?? ) uncheck "show material".
12 Oct 2023 13:12 #282819 by Franklin
Thanks Tommy, I tried this before and it didn't work, need to restart qtplasmac
12 Oct 2023 23:06 #282841 by phillc54
Replied by phillc54 on topic Toolpath problem?
I not seen this issue in Debian, is your Debian and LinuxCNC up to date?
15 Oct 2023 11:41 - 15 Oct 2023 11:45 #283053 by Franklin
I have uploaded images from this thread
forum.linuxcnc.org/9-installing-linuxcnc...cnc-x86-only?start=0
and also tried other images and the same error occurs.
I think it happens on specific hardware, this error is not detected on other PCs
Last edit: 15 Oct 2023 11:45 by Franklin.
Time to create page: 0.636 seconds
