QTPlasmaC open DXF directly
  • grijalvap
  • grijalvap's Avatar Topic Author
  • Elite Member
  • Elite Member
15 May 2023 18:23 #271413 by grijalvap
QTPlasmaC open DXF directly was created by grijalvap
HI Everybody.
First of all thanks for the great work you have been doing with QTplasmaC.
I want to bring the posibility of open DXF drawings directly in the QTPlasmaC User interface to the table.
The conversational shape library is very nice and useful, and I think that if we can integrate some kind of DXF2GCODE
converter on it it will be awesome.
17 May 2023 12:35 #271540 by andypugh
Replied by andypugh on topic QTPlasmaC open DXF directly
You should be able to do in your existing config with no code changes:
linuxcnc.org/docs/stable/html/config/ini...html#_filter_section
(ie, send DXF files automatically through dxf2gcode)
17 May 2023 23:26 #271578 by rodw
Replied by rodw on topic QTPlasmaC open DXF directly
I thought QTplasmac had a DXF filter built in. Maybe I am wrong. Try opening one...
Time to create page: 0.545 seconds
