- Thank you received: 22
QTPlasmaC with fourth axis - rotary
3 years 4 months ago #274377
by LesNewell
Replied by LesNewell on topic QTPlasmaC with fourth axis - rotary
I think we need to test this on a machine with a decently fast fourth axis. Marius, it's probably up to you for this.
Phill, just out of interest how do the A axis velocities compare to the first cut?
I found Mach3 works more smoothly with the rotary axis configured for 1 unit per rev instead of 360 units/rev. Do you think this would help here?
3 years 4 months ago #274378
by phillc54
This is from the docs:
Replied by phillc54 on topic QTPlasmaC with fourth axis - rotary
I didn't plot those, I can do tomorrow.Phill, just out of interest how do the A axis velocities compare to the first cut?
TBH I don't know if that is possible, I assumed angular joints/axes needed to be degrees.I found Mach3 works more smoothly with the rotary axis configured for 1 unit per rev instead of 360 units/rev. Do you think this would help here?
ANGULAR_UNITS = <units> - Specifies the machine units for rotational axes. Possible choices are deg, degree (360 per circle), rad, radian (2*π per circle), grad, or gon (400 per circle). This does not affect the angular units of NC code. In RS274NGC, A-, B- and C- words are always expressed in degrees.
- snowgoer540
- Thank you received: 907
3 years 4 months ago #274387
by snowgoer540
Would inverse time (G93) help with #2 at all? I know it's common on mills to use G93 with 4/5th axis moves.
Replied by snowgoer540 on topic QTPlasmaC with fourth axis - rotary
- My little rotary table is only capable of 150°/sec which is 25rpm
- LinuxCNC has poor path planning for axes other than X, Y, or Z
3 years 4 months ago #274389
by LesNewell
I generally recommend that the 4th axis is defined as a linear axis rather than angular. I'm not sure about LinuxCNC but some other controls treat rotary axes differently to linear axes. Functions such as rotary axis diameter compensation or 360 degree rollover can cause all sorts of unexpected issues.TBH I don't know if that is possible, I assumed angular joints/axes needed to be degrees.
3 years 4 months ago #274422
by phillc54
I will try to set up a Linear A axis next.
Interestingly it is a little faster but still a long way from what it should be. Rapid moves are fine but coordinated moves are ordinary to say the least.just out of interest how do the A axis velocities compare to the first cut?
- snowgoer540
3 years 4 months ago #274427
by snowgoer540
Here is a short video showing what I mean by G93. Perhaps sheetcam already exports code this way, I am not sure. But if nothing else, he has a good explanation of the problem and the solution.
Warning: Spoiler!
Time to create page: 0.286 seconds
