Modifying the Ohmic Probe Routine.
- Deveraux
- Thank you received: 8
15 Jun 2023 07:47 #273583
by Deveraux
Modifying the Ohmic Probe Routine. was created by Deveraux
I just mounted a pneumatic cylinder on my machine for ohmic probing since the method i used before (3d Printed Part with a copper ring around the plasmacutter nozzle) always gathered some molten metal which constantly set my z 0 wrong enough to mess qith my cuts). So far so good but im wondering if i could modify the probe routine so that the machine moves the x axis to compensate for the offset of the cylinder to the nozzle, then starts the normal probing routine, after which it moves back the x axis to move the nozzle where the probe happened ?
Where can i find the probe routine as far as i understood in plasmac 2.9 the probing is handled by the component so i probably have to modify the source code a little and then build from source to get it happening ? Or is there a simple solution for my Problem.
Thanks in advance for any input.
- phillc54
- Thank you received: 2100
15 Jun 2023 07:51 #273585
by phillc54
Replied by phillc54 on topic Modifying the Ohmic Probe Routine.
This feature is available in QtPlasmac in V2.9 or master branch:
linuxcnc.org/docs/devel/html/plasma/qtpl...lasma:offset_probing
- Deveraux
15 Jun 2023 07:54 #273586
by Deveraux
Replied by Deveraux on topic Modifying the Ohmic Probe Routine.
Thanks for the quick answer.
I had thought for a while now to upgrade from Plasmac to Qtplasmac now i finally have a reason to do so.
Thank you for the info.
Time to create page: 0.182 seconds
