- Thank you received: 7
HYS is the Hysteresis in Volts, 2 meaning a change of under 2V will not move the torch, so raise this to 3 or 4 or 5 and do some tests. For thin material, always 2.Hi Tommy
I have start with standart parameters wroten in a post by you i guess.
HYS - 2
d-t - We made a table and change with the thikness of the material so between 125 - 150, 4mm - 20mm
H-U - 200v
